Displacement Reconstructions in Ultrasound Elastography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Imaging Sciences Année : 2015
We consider the reconstruction of internal elastic displacements from ultrasound measurements , which finds applications in the medical imaging modality called elastography. By appropriate interferometry and windowed Fourier transforms of the ultrasound measurements, we propose a reconstruction procedure of the vectorial structure of spatially varying elastic displacements in biological tissues. This provides a modeling and generalization of scalar reconstruction procedures routinely used in elastography. The proposed algorithm is justified using a single scattering approximation and local asymptotic analysis. Its validity is assessed by numerical simulations.
ElasticDisplacementUltrasound-15-v2.pdf (1.18 Mo) Télécharger le fichier
hal-01188761 , version 1 (31-08-2015)
Guillaume Bal, Sébastien Imperiale. Displacement Reconstructions in Ultrasound Elastography. SIAM Journal on Imaging Sciences, 2015, 8 (2), pp.1070-1089. ⟨10.1137/140988504⟩. ⟨hal-01188761⟩
397 Consultations
399 Téléchargements
