Cell-paths in mono- and bichromatic line arrangements in the plane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2014
We prove that the dual graph of any arrangement of n lines in general position always contains a path of length at least n2/4. Further, we show that in every arrangement of n red and blue lines — in general position and not all of the same color — there is a simple path through at least n cells where red and blue lines are crossed alternatingly.
dmtcs-16-3-19.pdf (342.7 Ko) Télécharger le fichier
hal-01188902 , version 1 (31-08-2015)
Oswin Aichholzer, Jean Cardinal, Thomas Hackl, Ferran Hurtado, Matias Korman, et al.. Cell-paths in mono- and bichromatic line arrangements in the plane. Discrete Mathematics and Theoretical Computer Science, 2014, Vol. 16 no. 3 (3), pp.317--322. ⟨10.46298/dmtcs.2088⟩. ⟨hal-01188902⟩
Collections
TDS-MACS
205 Consultations
985 Téléchargements
