A four-sweep LBFS recognition algorithm for interval graphs
In their 2009 paper, Corneil et al. design a linear time interval graph recognition algorithm based on six sweeps of Lexicographic Breadth-First Search (LBFS) and prove its correctness. They believe that their corresponding 5-sweep LBFS interval graph recognition algorithm is also correct. Thanks to the LBFS structure theory established mainly by Corneil et al., we are able to present a 4-sweep LBFS algorithm which determines whether or not the input graph is a unit interval graph or an interval graph. Like the algorithm of Corneil et al., our algorithm does not involve any complicated data structure and can be executed in linear time.
