An exact algorithm for the generalized list T-coloring problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2014
The generalized list T-coloring is a common generalization of many graph coloring models, including classical coloring, L(p,q)-labeling, channel assignment and T-coloring. Every vertex from the input graph has a list of permitted labels. Moreover, every edge has a set of forbidden differences. We ask for a labeling of vertices of the input graph with natural numbers, in which every vertex gets a label from its list of permitted labels and the difference of labels of the endpoints of each edge does not belong to the set of forbidden differences of this edge. In this paper we present an exact algorithm solving this problem, running in time O*((τ+2)n), where τ is the maximum forbidden difference over all edges of the input graph and n is the number of its vertices. Moreover, we show how to improve this bound if the input graph has some special structure, e.g. a bounded maximum degree, no big induced stars or a perfect matching.
dmtcs-16-3-5.pdf (445.77 Ko) Télécharger le fichier
hal-01188909 , version 1 (31-08-2015)
Konstanty Junosza-Szaniawski, Pawel Rzazewski. An exact algorithm for the generalized list T-coloring problem. Discrete Mathematics and Theoretical Computer Science, 2014, Vol. 16 no. 3 (3), pp.77--94. ⟨10.46298/dmtcs.2095⟩. ⟨hal-01188909⟩
Collections
TDS-MACS
53 Consultations
1083 Téléchargements
