Guaranteed and robust a posteriori bounds for Laplace eigenvalues and eigenvectors: conforming approximations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Numerical Analysis Année : 2017
This paper derives a posteriori error estimates for conforming numerical approximations of the Laplace eigenvalue problem with a homogeneous Dirichlet boundary condition. In particular, upper and lower bounds for an arbitrary simple eigenvalue are given. These bounds are guaranteed, fully computable, and converge with optimal speed to the given exact eigenvalue. They are valid without restrictions on the computational mesh or on the approximate eigenvector; we only need to assume that the approximate eigenvalue is separated from the surrounding smaller and larger exact ones, which can be checked in practice. Guaranteed, fully computable, optimally convergent, and polynomial-degree robust bounds on the energy error in the approximation of the associated eigenvector are derived as well, under the same hypotheses. Remarkably, there appears no unknown (solution-, regularity-, or polynomial-degree-dependent) constant in our theory, and no convexity/regularity assumption on the computational domain/exact eigenvector(s) is needed. Two improvements of the multiplicative constant appearing in our estimates are presented. First, it is reduced by a fixed factor under an explicit, a posteriori calculable condition on the mesh and on the approximate eigenvector--eigenvalue pair. Second, when an elliptic regularity assumption on the corresponding source problem is satisfied with known constants, the multiplicative factor can be brought to the optimal value of one. Inexact algebraic solvers are taken into account; the estimates are valid on each iteration and can serve for the design of adaptive stopping criteria. The application of our framework to conforming finite element approximations of arbitrary polynomial degree is provided, along with a numerical illustration on a set of test problems.
a_post_Lapl_conf.pdf (1.82 Mo) Télécharger le fichier
hal-01194364 , version 1 (06-09-2015)
hal-01194364 , version 2 (27-06-2016)
hal-01194364 , version 3 (15-12-2016)
Eric Cancès, Geneviève Dusson, Yvon Maday, Benjamin Stamm, Martin Vohralík. Guaranteed and robust a posteriori bounds for Laplace eigenvalues and eigenvectors: conforming approximations. SIAM Journal on Numerical Analysis, 2017, 55 (5), pp.2228-2254. ⟨10.1137/15M1038633⟩. ⟨hal-01194364v3⟩
883 Consultations
659 Téléchargements
