On density of truth of the intuitionistic logic in one variable - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2008
In this paper we focus on the intuitionistic propositional logic with one propositional variable. More precisely we consider the standard fragment $\{ \to ,\vee ,\bot \}$ of this logic and compute the proportion of tautologies among all formulas. It turns out that this proportion is different from the analog one in the classical logic case.
dmAI0130.pdf (224.59 Ko) Télécharger le fichier
hal-01194665 , version 1 (07-09-2015)
Zofia Kostrzycka. On density of truth of the intuitionistic logic in one variable. Fifth Colloquium on Mathematics and Computer Science, 2008, Kiel, Germany. pp.449-460, ⟨10.46298/dmtcs.3583⟩. ⟨hal-01194665⟩
Collections
TDS-MACS
46 Consultations
600 Téléchargements
