Convergence to the coalescent and its relation to the time back to the most recent common ancestor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2008
For the class of haploid exchangeable population models with non-overlapping generations and population size $N$ it is shown that, as $N$ tends to infinity, convergence of the time-scaled ancestral process to Kingman's coalescent and convergence in distribution of the scaled times back to the most recent common ancestor (MRCA) to the corresponding times back to the MRCA of the Kingman coalescent are equivalent. Extensions of this equivalence are derived for exchangeable population models being in the domain of attraction of a coalescent process with multiple collisions. The proofs are based on the property that the total rates of a coalescent with multiple collisions already determine the distribution of the coalescent. It is finally shown that similar results cannot be obtained for the full class of exchangeable coalescents allowing for simultaneous multiple collisions of ancestral lineages, essentially because the total rates do not determine the distribution of a general exchangeable coalescent.
dmAI0120.pdf (236.04 Ko) Télécharger le fichier
hal-01194673 , version 1 (07-09-2015)
Martin Möhle. Convergence to the coalescent and its relation to the time back to the most recent common ancestor. Fifth Colloquium on Mathematics and Computer Science, 2008, Kiel, Germany. pp.311-324, ⟨10.46298/dmtcs.3573⟩. ⟨hal-01194673⟩
Collections
TDS-MACS
191 Consultations
593 Téléchargements
