Random Records and Cuttings in Split Trees: Extended Abstract - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2008
We study the number of records in random split trees on $n$ randomly labelled vertices. Equivalently the number of random cuttings required to eliminate an arbitrary random split tree can be studied. After normalization the distributions are shown to be asymptotically $1$-stable. This work is a generalization of our earlier results for the random binary search tree which is one specific case of split trees. Other important examples of split trees include $m$-ary search trees, quadtrees, median of $(2k+1)$-trees, simplex trees, tries and digital search trees.
dmAI0117.pdf (245.88 Ko) Télécharger le fichier
hal-01194685 , version 1 (07-09-2015)
Cecilia Holmgren. Random Records and Cuttings in Split Trees: Extended Abstract. Fifth Colloquium on Mathematics and Computer Science, 2008, Kiel, Germany. pp.269-282, ⟨10.46298/dmtcs.3570⟩. ⟨hal-01194685⟩
Collections
TDS-MACS
63 Consultations
635 Téléchargements
