The continuous limit of large random planar maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2008
We discuss scaling limits of random planar maps chosen uniformly over the set of all $2p$-angulations with $n$ faces. This leads to a limiting space called the Brownian map, which is viewed as a random compact metric space. Although we are not able to prove the uniqueness of the distribution of the Brownian map, many of its properties can be investigated in detail. In particular, we obtain a complete description of the geodesics starting from the distinguished point called the root. We give applications to various properties of large random planar maps.
dmAI0101.pdf (293.66 Ko) Télécharger le fichier
hal-01194691 , version 1 (07-09-2015)
Jean-François Le Gall. The continuous limit of large random planar maps. Fifth Colloquium on Mathematics and Computer Science, 2008, Kiel, Germany. pp.1-18, ⟨10.46298/dmtcs.3554⟩. ⟨hal-01194691⟩
61 Consultations
552 Téléchargements
