Conformal mapping for cavity inverse problem: an explicit reconstruction formula - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
In this paper, we address a classical case of the Calder\'on (or conductivity) inverse problem in dimension two. We aim to recover the location and the shape of a single cavity $\omega$ (with boundary $\gamma$) contained in a domain $\Omega$ (with boundary $\Gamma$) from the knowledge of the Dirichlet-to-Neumann (DtN) map $\Lambda_\gamma: f \longmapsto \partial_n u^f|_{\Gamma}$, where $u^f$ is harmonic in $\Omega\setminus\overline{\omega}$, $u^f|_{\Gamma}=f$ and $u^f|_{\gamma}=c^f$, $c^f$ being the constant such that $\int_{\gamma}\partial_n u^f\,{\rm d}s=0$. We obtain an explicit formula for the complex coefficients $a_m$ arising in the expression of the Riemann map $z\longmapsto a_1 z + a_0 + \sum_{m\leqslant -1} a_m z^{m}$ that conformally maps the exterior of the unit disk onto the exterior of $\omega$. This formula is derived by using two ingredients: a new factorization result of the DtN map and the so-called generalized P\'olia-Szeg\"o tensors (GPST) of the cavity. As a byproduct of our analysis, we also prove the analytic dependence of the coefficients $a_m$ with respect to the DtN. Numerical results are provided to illustrate the efficiency and simplicity of the method.
reconstruction_REVISED_HAL.pdf (1018.62 Ko) Télécharger le fichier
hal-01196111 , version 1 (09-09-2015)
hal-01196111 , version 2 (24-11-2015)
hal-01196111 , version 3 (24-06-2016)
hal-01196111 , version 4 (24-06-2016)
  • HAL Id : hal-01196111 , version 3
Alexandre Munnier, Karim Ramdani. Conformal mapping for cavity inverse problem: an explicit reconstruction formula. 2016. ⟨hal-01196111v3⟩
315 Consultations
437 Téléchargements
