Output sensitive algorithms for covering many points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2015
In this paper we devise some output sensitive algorithms for a problem where a set of points and a positive integer, m, are given and the goal is to cover a maximal number of these points with m disks. We introduce a parameter, ρ, as the maximum number of points that one disk can cover and we analyse the algorithms based on this parameter. At first, we solve the problem for m=1 in O(nρ) time, which improves the previous O(n2) time algorithm for this problem. Then we solve the problem for m=2 in O(nρ + 3 log ρ) time, which improves the previous O(n3 log n) algorithm for this problem. Our algorithms outperform the previous algorithms because ρ is much smaller than n in many cases. Finally, we extend the algorithm for any value of m and solve the problem in O(mnρ + (mρ)2m - 1 log mρ) time. The previous algorithm for this problem runs in O(n2m - 1 log n) time and our algorithm usually runs faster than the previous algorithm because mρ is smaller than n in many cases. We obtain output sensitive algorithms by confining the areas that we should search for the result. The techniques used in this paper may be applicable in other covering problems to obtain faster algorithms.
dmtcs-17-1-20.pdf (331.08 Ko) Télécharger le fichier
hal-01196845 , version 1 (10-09-2015)
Hossein Ghasemalizadeh, Mohammadreza Razzazi. Output sensitive algorithms for covering many points. Discrete Mathematics and Theoretical Computer Science, 2015, Vol. 17 no. 1 (1), pp.309--316. ⟨10.46298/dmtcs.2102⟩. ⟨hal-01196845⟩
Collections
TDS-MACS
47 Consultations
956 Téléchargements
