On substitution tilings of the plane with n-fold rotational symmetry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2015
A method is described for constructing, with computer assistance, planar substitution tilings that have n-fold rotational symmetry. This method uses as prototiles the set of rhombs with angles that are integer multiples of pi/n, and includes various special cases that have already been constructed by hand for low values of n. An example constructed by this method for n = 11 is exhibited; this is the first substitution tiling with elevenfold symmetry appearing in the literature.
Mots clés
dmtcs-17-1-26.pdf (2.52 Mo) Télécharger le fichier
hal-01196852 , version 1 (10-09-2015)
Gregory R. Maloney. On substitution tilings of the plane with n-fold rotational symmetry. Discrete Mathematics and Theoretical Computer Science, 2015, Vol. 17 no. 1 (1), pp.397-—414. ⟨10.46298/dmtcs.2108⟩. ⟨hal-01196852⟩
Collections
TDS-MACS
59 Consultations
1064 Téléchargements
