How often should you clean your room? - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Discrete Mathematics and Theoretical Computer Science Year : 2015
We introduce and study a combinatorial optimization problem motivated by the question in the title. In the simple case where you use all objects in your room equally often, we investigate asymptotics of the optimal time to clean up in terms of the number of objects in your room. In particular, we prove a logarithmic upper bound, solve an approximate version of this problem, and conjecture a precise logarithmic asymptotic.
dmtcs-17-1-27.pdf (412.01 Ko) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
hal-01196853 , version 1 (10-09-2015)
Identifiers
Cite
Kimball Martin, Krishnan Shankar. How often should you clean your room?. Discrete Mathematics and Theoretical Computer Science, 2015, Vol. 17 no. 1 (1), pp.415-—444. ⟨10.46298/dmtcs.2109⟩. ⟨hal-01196853⟩
Collections
TDS-MACS
43 View
950 Download
Share
