Snarks with total chromatic number 5 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2015
A k-total-coloring of G is an assignment of k colors to the edges and vertices of G, so that adjacent and incident elements have different colors. The total chromatic number of G, denoted by χT(G), is the least k for which G has a k-total-coloring. It was proved by Rosenfeld that the total chromatic number of a cubic graph is either 4 or 5. Cubic graphs with χT = 4 are said to be Type 1, and cubic graphs with χT = 5 are said to be Type 2. Snarks are cyclically 4-edge-connected cubic graphs that do not allow a 3-edge-coloring. In 2003, Cavicchioli et al. asked for a Type 2 snark with girth at least 5. As neither Type 2 cubic graphs with girth at least 5 nor Type 2 snarks are known, this is taking two steps at once, and the two requirements of being a snark and having girth at least 5 should better be treated independently. In this paper we will show that the property of being a snark can be combined with being Type 2. We will give a construction that gives Type 2 snarks for each even vertex number n≥40. We will also give the result of a computer search showing that among all Type 2 cubic graphs on up to 32 vertices, all but three contain an induced chordless cycle of length 4. These three exceptions contain triangles. The question of the existence of a Type 2 cubic graph with girth at least 5 remains open.
dmtcs-17-1-24.pdf (353.15 Ko) Télécharger le fichier
hal-01196855 , version 1 (10-09-2015)
Gunnar Brinkmann, Myriam Preissmann, Diana Sasaki. Snarks with total chromatic number 5. Discrete Mathematics and Theoretical Computer Science, 2015, Vol. 17 no. 1 (1), pp.369--382. ⟨10.46298/dmtcs.2111⟩. ⟨hal-01196855⟩
544 Consultations
926 Téléchargements
