On the Hausdorff measure of regular ω-languages in Cantor space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2015
This paper deals with the calculation of the Hausdorff measure of regular ω-languages, that is, subsets of the Cantor space definable by finite automata. Using methods for decomposing regular ω-languages into disjoint unions of parts of simple structure we derive two sufficient conditions under which ω-languages with a closure definable by a finite automaton have the same Hausdorff measure as this closure. The first of these condition is related to the homogeneity of the local behaviour of the Hausdorff dimension of the underlying set, and the other with a certain topological density of the set in its closure.
dmtcs-17-1-23.pdf (299.11 Ko) Télécharger le fichier
hal-01196856 , version 1 (10-09-2015)
Ludwig Staiger. On the Hausdorff measure of regular ω-languages in Cantor space. Discrete Mathematics and Theoretical Computer Science, 2015, Vol. 17 no. 1 (1), pp.357--368. ⟨10.46298/dmtcs.2112⟩. ⟨hal-01196856⟩
Collections
TDS-MACS
138 Consultations
961 Téléchargements
