Data Streams as Random Permutations: the Distinct Element Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2012
In this paper, we show that data streams can sometimes usefully be studied as random permutations. This simple observation allows a wealth of classical and recent results from combinatorics to be recycled, with minimal effort, as estimators for various statistics over data streams. We illustrate this by introducing RECORDINALITY, an algorithm which estimates the number of distinct elements in a stream by counting the number of $k$-records occurring in it. The algorithm has a score of interesting properties, such as providing a random sample of the set underlying the stream. To the best of our knowledge, a modified version of RECORDINALITY is the first cardinality estimation algorithm which, in the random-order model, uses neither sampling nor hashing.
dmAQ0124.pdf (497.33 Ko) Télécharger le fichier
hal-01197221 , version 1 (11-09-2015)
Ahmed Helmi, Jérémie Lumbroso, Conrado Martínez, Alfredo Viola. Data Streams as Random Permutations: the Distinct Element Problem. 23rd International Meeting on Probabilistic, Combinatorial, and Asymptotic Methods in the Analysis of Algorithms (AofA'12), Jun 2012, Montreal, Canada. pp.323-338, ⟨10.46298/dmtcs.3002⟩. ⟨hal-01197221⟩
335 Consultations
1017 Téléchargements
