The Limiting Distribution for the Number of Symbol Comparisons Used by QuickSort is Nondegenerate (Extended Abstract) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2012
In a continuous-time setting, Fill (2012) proved, for a large class of probabilistic sources, that the number of symbol comparisons used by $\texttt{QuickSort}$, when centered by subtracting the mean and scaled by dividing by time, has a limiting distribution, but proved little about that limiting random variable $Y$—not even that it is nondegenerate. We establish the nondegeneracy of $Y$. The proof is perhaps surprisingly difficult.
dmAQ0126.pdf (329.65 Ko) Télécharger le fichier
hal-01197223 , version 1 (11-09-2015)
Patrick Bindjeme, James Allen Fill. The Limiting Distribution for the Number of Symbol Comparisons Used by QuickSort is Nondegenerate (Extended Abstract). 23rd International Meeting on Probabilistic, Combinatorial, and Asymptotic Methods in the Analysis of Algorithms (AofA'12), 2012, Montreal, Canada. pp.349-360, ⟨10.46298/dmtcs.3004⟩. ⟨hal-01197223⟩
Collections
TDS-MACS
51 Consultations
547 Téléchargements
