Matching solid shapes in arbitrary dimension via random sampling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2012
We give simple probabilistic algorithms that approximately maximize the volume of overlap of two solid, i.e. full-dimensional, shapes under translations and rigid motions. The shapes are subsets of $ℝ^d$ where $d≥ 2$. The algorithms approximate with respect to an pre-specified additive error and succeed with high probability. Apart from measurability assumptions, we only require that points from the shapes can be generated uniformly at random. An important example are shapes given as finite unions of simplices that have pairwise disjoint interiors.
dmAQ0114.pdf (342.12 Ko) Télécharger le fichier
hal-01197244 , version 1 (11-09-2015)
Daria Schymura. Matching solid shapes in arbitrary dimension via random sampling. 23rd International Meeting on Probabilistic, Combinatorial, and Asymptotic Methods in the Analysis of Algorithms (AofA'12), 2012, Montreal, Canada. pp.167-178, ⟨10.46298/dmtcs.2992⟩. ⟨hal-01197244⟩
Collections
TDS-MACS
84 Consultations
481 Téléchargements
