On the number of transversals in random trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2012
We study transversals in random trees with n vertices asymptotically as n tends to infinity. Our investigation treats the average number of transversals of fixed size, the size of a random transversal as well as the probability that a random subset of the vertex set of a tree is a transversal for the class of simply generated trees and for Pólya trees. The last parameter was already studied by Devroye for simply generated trees. We offer an alternative proof based on generating functions and singularity analysis and extend the result to Pólya trees.
dmAQ0112.pdf (297.09 Ko) Télécharger le fichier
hal-01197246 , version 1 (11-09-2015)
Bernhard Gittenberger, Veronika Kraus. On the number of transversals in random trees. 23rd International Meeting on Probabilistic, Combinatorial, and Asymptotic Methods in the Analysis of Algorithms (AofA'12), 2012, Montreal, Canada. pp.141-154, ⟨10.46298/dmtcs.2990⟩. ⟨hal-01197246⟩
Collections
TDS-MACS
129 Consultations
635 Téléchargements
