Positroids, non-crossing partitions, and positively oriented matroids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2014
We investigate the role that non-crossing partitions play in the study of positroids, a class of matroids introduced by Postnikov. We prove that every positroid can be constructed uniquely by choosing a non-crossing partition on the ground set, and then freely placing the structure of a connected positroid on each of the blocks of the partition. We use this to enumerate connected positroids, and we prove that the probability that a positroid on [n] is connected equals $1/e^2$ asymptotically. We also prove da Silva's 1987 conjecture that any positively oriented matroid is a positroid; that is, it can be realized by a set of vectors in a real vector space. It follows from this result that the positive matroid Grassmannian (or positive MacPhersonian) is homeomorphic to a closed ball.
dmAT0157.pdf (371.77 Ko) Télécharger le fichier
hal-01207540 , version 1 (01-10-2015)
Federico Ardila, Felipe Rincón, Lauren Williams. Positroids, non-crossing partitions, and positively oriented matroids. 26th International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2014), 2014, Chicago, United States. pp.655-666, ⟨10.46298/dmtcs.2431⟩. ⟨hal-01207540⟩
Collections
TDS-MACS
281 Consultations
902 Téléchargements
