Observer design for a schistosomiasis model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Biosciences Année : 2015
This paper deals with the state estimation for a schistosomiasis infection dynamical model described by a continuous nonlinear system when only the infected human population is measured. The central idea is studied following two major angles. On the one hand, when all the parameters of the model are supposed to be well known, we construct a simple observer and a high-gain Luenberger observer based on a canonical controller form and conceived for the nonlinear dynamics where it is implemented. On the other hand, when the nonlinear uncertain continuous-time system is in a bounded-error context, we introduce a method for designing a guaranteed interval observer. Numerical simulations are included in order to test the behavior and the performance of the given observers.
MBS-D-14-00301-v2.pdf (5.69 Mo) Télécharger le fichier
hal-01211822 , version 1 (05-10-2015)
Mouhamadou Diaby, Abderrahman Iggidr, Mamadou Sy. Observer design for a schistosomiasis model. Mathematical Biosciences, 2015, 269, pp.17--29. ⟨10.1016/j.mbs.2015.08.008⟩. ⟨hal-01211822⟩
159 Consultations
158 Téléchargements
