From DSL to HPC Component-Based Runtime: A Multi-Stencil DSL Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
High performance architectures evolve continuously to be more powerful. Such architectures also usually become more difficult to use efficiently. As a scientist is not a low level and high performance programming expert, Domain Specific Languages (DSLs) are a promising solution to automatically and efficiently write high performance codes. However, if DSLs ease programming for scientists, maintainability and portability issues are transferred from scientists to DSL de- signers. This paper deals with an approach to improve main- tainability and programming productivity of DSLs through the generation of a component-based parallel runtime. To study it, the paper presents a DSL for multi-stencil pro- grams, that is evaluated on a real-case of shallow water equations.
article.pdf (527.59 Ko) Télécharger le fichier
hal-01215992 , version 1 (16-08-2016)
Julien Bigot, Hélène Coullon, Christian Pérez. From DSL to HPC Component-Based Runtime: A Multi-Stencil DSL Case Study. WOLFHPC 2015 (Fifth International Workshop on Domain-Specific Languages and High-Level Frameworks for High Performance Computing), Nov 2015, co-located with SC'15, Austin, Texas, United States. pp.10, ⟨10.1145/2830018.2830020⟩. ⟨hal-01215992⟩
572 Consultations
235 Téléchargements
