Sparse Polynomial Systems with many Positive Solutions from Bipartite Simplicial Complexes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Consider a regular triangulation of the convex-hull $P$ of a set $\mathcal A$ of $n$ points in $\mathbb R^d$, and a real matrix $C$ of size $d \times n$. A version of Viro's method allows to construct from these data an unmixed polynomial system with support $\mathcal A$ and coefficient matrix $C$ whose number of positive solutions is bounded from below by the number of $d$-simplices which are positively decorated by $C$. We show that all the $d$-simplices of a triangulation can be positively decorated if and only if the triangulation is balanced, which in turn is equivalent to the fact that its dual graph is bipartite. This allows us to identify, among classical families, monomial supports which admit maximally positive systems, i.e. systems all toric complex solutions of which are real and positive. These families give some evidence in favor of a conjecture due to Bihan. We also use this technique in order to construct fewnomial systems with many positive solutions. This is done by considering a simplicial complex with bipartite dual graph included in a regular triangulation of the cyclic polytope.
notes.pdf (272.95 Ko) Télécharger le fichier
hal-01217547 , version 1 (19-10-2015)
hal-01217547 , version 2 (18-04-2016)
Frédéric Bihan, Pierre-Jean Spaenlehauer. Sparse Polynomial Systems with many Positive Solutions from Bipartite Simplicial Complexes. 2016. ⟨hal-01217547v2⟩
432 Consultations
143 Téléchargements
