Vector Lyapunov Function based Stability for a Class of Impulsive Systems
This paper contributes to the exponential stability analysis for impulsive dynamical systems based on a vector Lyapunov function and its divergence operator. The method relies on a 2D time domain representation. The results are applied to analyze the exponential stability of linear impulsive systems based on LMIs. Some examples illustrate the feasibility of the proposed approach.
Automatique / Robotique
