On the interaction problem between a compressible fluid and a Saint-Venant Kirchhoff elastic structure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Differential Equations Année : 2017
In this paper, we consider an elastic structure immersed in a compressible viscous fluid. The motion of the fluid is described by the compressible Navier-Stokes equations whereas the motion of the structure is given by the nonlinear Saint-Venant Kirchhoff model. For this model, we prove the existence and uniqueness of regular solutions defined locally in time. To do so, we first rewrite the nonlinearity in the elasticity equation in an adequate way. Then, we introduce a linearized problem and prove that this problem admits a unique regular solution. To obtain time regularity on the solution, we use energy estimates on the unknowns and their successive derivatives in time and to obtain spatial regularity, we use elliptic estimates. At last, to come back to the nonlinear problem, we use a fixed point theorem.
Boulakia_Guerrero2.pdf (404.31 Ko) Télécharger le fichier
hal-01229577 , version 1 (20-11-2015)
  • HAL Id : hal-01229577 , version 1
Muriel Boulakia, Sergio Guerrero. On the interaction problem between a compressible fluid and a Saint-Venant Kirchhoff elastic structure. Advances in Differential Equations, 2017, 22 (1-2). ⟨hal-01229577⟩
196 Consultations
152 Téléchargements
