The probability of planarity of a random graph near the critical point - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2013
Erdős and Rényi conjectured in 1960 that the limiting probability $p$ that a random graph with $n$ vertices and $M=n/2$ edges is planar exists. It has been shown that indeed p exists and is a constant strictly between 0 and 1. In this paper we answer completely this long standing question by finding an exact expression for this probability, whose approximate value turns out to be $p ≈0.99780$. More generally, we compute the probability of planarity at the critical window of width $n^{2/3}$ around the critical point $M=n/2$. We extend these results to some classes of graphs closed under taking minors. As an example, we show that the probability of being series-parallel converges to 0.98003. Our proofs rely on exploiting the structure of random graphs in the critical window, obtained previously by Janson, Łuczak and Wierman, by means of generating functions and analytic methods. This is a striking example of how analytic combinatorics can be applied to classical problems on random graphs.
dmAS0167.pdf (305.82 Ko) Télécharger le fichier
hal-01229657 , version 1 (17-11-2015)
Marc Noy, Vlady Ravelomanana, Juanjo Rué. The probability of planarity of a random graph near the critical point. 25th International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2013), 2013, Paris, France. pp.791-802, ⟨10.46298/dmtcs.2343⟩. ⟨hal-01229657⟩
62 Consultations
985 Téléchargements
