Generalized monotone triangles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2013
In a recent work, the combinatorial interpretation of the polynomial $\alpha (n; k_1,k_2,\ldots,k_n)$ counting the number of Monotone Triangles with bottom row $k_1 < k_2 < ⋯< k_n$ was extended to weakly decreasing sequences $k_1 ≥k_2 ≥⋯≥k_n$. In this case the evaluation of the polynomial is equal to a signed enumeration of objects called Decreasing Monotone Triangles. In this paper we define Generalized Monotone Triangles – a joint generalization of both ordinary Monotone Triangles and Decreasing Monotone Triangles. As main result of the paper we prove that the evaluation of $\alpha (n; k_1,k_2,\ldots,k_n)$ at arbitrary $(k_1,k_2,\ldots,k_n) ∈ \mathbb{Z}^n$ is a signed enumeration of Generalized Monotone Triangles with bottom row $(k_1,k_2,\ldots,k_n)$. Computational experiments indicate that certain evaluations of the polynomial at integral sequences yield well-known round numbers related to Alternating Sign Matrices. The main result provides a combinatorial interpretation of the conjectured identities and could turn out useful in giving bijective proofs.
dmAS0155.pdf (325.63 Ko) Télécharger le fichier
hal-01229671 , version 1 (17-11-2015)
Lukas Riegler. Generalized monotone triangles. 25th International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2013), 2013, Paris, France. pp.647-658, ⟨10.46298/dmtcs.2331⟩. ⟨hal-01229671⟩
Collections
TDS-MACS
50 Consultations
580 Téléchargements
