Pattern-avoiding Dyck paths - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2013
We introduce the notion of $\textit{pattern}$ in the context of lattice paths, and investigate it in the specific case of Dyck paths. Similarly to the case of permutations, the pattern-containment relation defines a poset structure on the set of all Dyck paths, which we call the $\textit{Dyck pattern poset}$. Given a Dyck path $P$, we determine a formula for the number of Dyck paths covered by $P$, as well as for the number of Dyck paths covering $P$. We then address some typical pattern-avoidance issues, enumerating some classes of pattern-avoiding Dyck paths. Finally, we offer a conjecture concerning the asymptotic behavior of the sequence counting Dyck paths avoiding a generic pattern and we pose a series of open problems regarding the structure of the Dyck pattern poset.
dmAS0158.pdf (388.54 Ko) Télécharger le fichier
hal-01229675 , version 1 (17-11-2015)
Antonio Bernini, Luca Ferrari, Renzo Pinzani, Julian West. Pattern-avoiding Dyck paths. 25th International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2013), 2013, Paris, France. pp.683-694, ⟨10.46298/dmtcs.2334⟩. ⟨hal-01229675⟩
Collections
TDS-MACS
133 Consultations
1131 Téléchargements
