Divisors on graphs, Connected flags, and Syzygies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2013
We study the binomial and monomial ideals arising from linear equivalence of divisors on graphs from the point of view of Gröbner theory. We give an explicit description of a minimal Gröbner basis for each higher syzygy module. In each case the given minimal Gröbner basis is also a minimal generating set. The Betti numbers of $I_G$ and its initial ideal (with respect to a natural term order) coincide and they correspond to the number of ``connected flags'' in $G$. Moreover, the Betti numbers are independent of the characteristic of the base field.
dmAS0175.pdf (391.06 Ko) Télécharger le fichier
hal-01229678 , version 1 (17-11-2015)
Fatemeh Mohammadi, Farbod Shokrieh. Divisors on graphs, Connected flags, and Syzygies. 25th International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2013), 2013, Paris, France. pp.885-896, ⟨10.46298/dmtcs.2351⟩. ⟨hal-01229678⟩
Collections
TDS-MACS
45 Consultations
825 Téléchargements
