The height of the Lyndon tree - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2013
Lucas Mercier
  • Fonction : Auteur
  • PersonId : 775642
  • IdRef : 195497066
Philippe Chassaing
We consider the set $\mathcal{L}_n<$ of n-letters long Lyndon words on the alphabet $\mathcal{A}=\{0,1\}$. For a random uniform element ${L_n}$ of the set $\mathcal{L}_n$, the binary tree $\mathfrak{L} (L_n)$ obtained by successive standard factorization of $L_n$ and of the factors produced by these factorization is the $\textit{Lyndon tree}$ of $L_n$. We prove that the height $H_n$ of $\mathfrak{L} (L_n)$ satisfies $\lim \limits_n \frac{H_n}{\mathsf{ln}n}=\Delta$, in which the constant $\Delta$ is solution of an equation involving large deviation rate functions related to the asymptotics of Eulerian numbers ($\Delta ≃5.092\dots $). The convergence is the convergence in probability of random variables.
dmAS0181.pdf (776.65 Ko) Télécharger le fichier
hal-01229697 , version 1 (17-11-2015)
Lucas Mercier, Philippe Chassaing. The height of the Lyndon tree. 25th International Conference on Formal Power Series and Algebraic Combinatorics (FPSAC 2013), 2013, Paris, France. pp.957-968, ⟨10.46298/dmtcs.2357⟩. ⟨hal-01229697⟩
97 Consultations
642 Téléchargements
