Structure and function of the global ocean microbiome - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Science Année : 2015
Samuel Chaffron
Karine Labadie
Bardya Djahanschiri
  • Fonction : Auteur
Adriana A. Alberti
Francisco M. Cornejo-Castillo
  • Fonction : Auteur
Paul I. Costea
  • Fonction : Auteur
Corinne Cruaud
Isabel Ferrera
  • Fonction : Auteur
Lionel Guidi
Florian Kokoszka
  • Fonction : Auteur
Gipsi Lima-Mendez
  • Fonction : Auteur
Julie Poulain
Bonnie T. Poulos
  • Fonction : Auteur
Marta Royo-Llonch
  • Fonction : Auteur
Hugo Sarmento
Sara Vieira-Silva
Céline Dimier
  • Fonction : Auteur
Sarah Searson
  • Fonction : Auteur
Chris Bowler
Pascal Hingamp
Daniele Iudicone
Hiroyuki Ogata
Stéphane Pesant
  • Fonction : Auteur
Sabrina Speich
  • Fonction : Auteur
Lars Stemmann
Matthew B. Sullivan
  • Fonction : Auteur
Patrick Wincker
Silvia G. Acinas
  • Fonction : Auteur
Microbes are dominant drivers of biogeochemical processes, yet drawing a global picture of functional diversity, microbial community structure, and their ecological determinants remains a grand challenge. We analyzed 7.2 terabases of metagenomic data from 243 Tara Oceans samples from 68 locations in epipelagic and mesopelagic waters across the globe to generate an ocean microbial reference gene catalog with >40 million nonredundant, mostly novel sequences from viruses, prokaryotes, and picoeukaryotes. Using 139 prokaryote-enriched samples, containing >35,000 species, we show vertical stratification with epipelagic community composition mostly driven by temperature rather than other environmental factors or geography. We identify ocean microbial core functionality and reveal that >73% of its abundance is shared with the human gut microbiome despite the physicochemical differences between these two ecosystems.
Sunagawa_et_al_2015_preprint.pdf (2.06 Mo) Télécharger le fichier
hal-01233742 , version 1 (14-04-2021)
Shinichi Sunagawa, Luis Pedro Coelho, Samuel Chaffron, Jens Roat Kultima, Karine Labadie, et al.. Structure and function of the global ocean microbiome. Science, 2015, 348 (6237), pp.1261359. ⟨10.1126/science.1261359⟩. ⟨hal-01233742⟩
31698 Consultations
442 Téléchargements
