Migrations in the Rosenzweig-MacArthur model and the "atto-fox" problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue Africaine de Recherche en Informatique et Mathématiques Appliquées Année : 2015
The Rosenzweig-MacArthur model is a system of two ODEs used in population dynamics to modelize the predator-prey relationship. For certain values of the parameters the differential system exhibits a unique stable limit cycle. When the dynamics of the prey is faster than the dynamics of the predator, during oscillations along the limit cycle, the density of preys take so small values that it cannot modelize any actual population. This phenomenon is known as the "atto-fox" problem. In this paper we assume that the populations are living in two patches and are able to migrate from one patch to another. We give conditions for which the migration can prevent the density of prey being too small.
Fichier non déposé
hal-01235211 , version 1 (29-11-2015)
hal-01235211 , version 2 (24-05-2016)
  • HAL Id : hal-01235211 , version 1
Claude Lobry, Tewfik Sari. Migrations in the Rosenzweig-MacArthur model and the "atto-fox" problem. Revue Africaine de Recherche en Informatique et Mathématiques Appliquées, 2015, 20, pp.95-125. ⟨hal-01235211v1⟩
751 Consultations
1499 Téléchargements
