Numeric and Certified Isolation of the Singularities of the Projection of a Smooth Space Curve
Let CP ∩Q be a smooth real analytic curve embedded in R 3 , defined as the solutions of real analytic equations of the form P (x, y, z) = Q(x, y, z) = 0 or P (x, y, z) = ∂P ∂z = 0. Our main objective is to describe its projection C onto the (x, y)-plane. In general, the curve C is not a regular submanifold of R 2 and describing it requires to isolate the points of its singularity locus Σ. After describing the types of singularities that can arise under some assumptions on P and Q, we present a new method to isolate the points of Σ. We experimented our method on pairs of independent random polynomials (P, Q) and on pairs of random polynomials of the form (P, ∂P ∂z) and got promising results.
