New interface
Reports (Research report)
The Cost of Installing a New Communication Schedule in a 6TiSCH Low-Power Wireless Network using CoAP (Extended Version)
Abstract : Scheduling in a IEEE802.15.4e TSCH (6TiSCH) low-power wireless network can be done in a centralized or distributed way. When using centralized scheduling, a scheduler installs a communication schedule into the network. This can be done in a standards-based way using CoAP. In this report, we compute the number of packets and the latency this takes, on real-world examples. The result is that the cost is very high using today's standards, much higher than when using an ad-hoc solution such as OCARI. We conclude by making recommendations to drastically reduce the number of messages and improve the efficiency of the standardized approach.
Document type :
Complete list of metadata
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01239994
Contributor : Pascale Minet Connect in order to contact the contributor
Submitted on : Wednesday, December 9, 2015 - 5:17:48 PM
Last modification on : Wednesday, October 26, 2022 - 8:15:03 AM
Long-term archiving on: : Friday, May 5, 2017 - 5:30:22 PM
File
RR-8817Dec2015.pdf
Identifiers
  • HAL Id : hal-01239994, version 2
Collections
Citation
Erwan Livolant, Pascale Minet, Thomas Watteyne. The Cost of Installing a New Communication Schedule in a 6TiSCH Low-Power Wireless Network using CoAP (Extended Version). [Research Report] RR-8817, Inria. 2015, pp.56. ⟨hal-01239994v2⟩
Share
Metrics
Record views
235
Files downloads
189
