Weak Dirichlet processes with jumps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
This paper develops systematically stochastic calculus via regularization in the case of jump processes. In particular one continues the analysis of real-valued càdlàg weak Dirichlet processes with respect to a given filtration. Such a process is the sum of a local martingale and an adapted process A such that [N, A] = 0, for any continuous local martingale N. In particular, given a function u : [0, T ] × R → R, which is of class C^{0,1} (or sometimes less), we provide a chain rule type expansion for X_t = u(t, X_t) which stands in applications for a chain Itô type rule.
E_FR_corrente1.pdf (342.2 Ko) Télécharger le fichier
hal-01241073 , version 1 (09-12-2015)
hal-01241073 , version 2 (16-12-2016)
hal-01241073 , version 3 (01-03-2017)
Elena Bandini, Francesco Russo. Weak Dirichlet processes with jumps. 2015. ⟨hal-01241073v1⟩
187 Consultations
221 Téléchargements
