Weak Dirichlet processes with jumps
This paper develops systematically stochastic calculus via regularization in the case of jump processes. In particular one continues the analysis of real-valued càdlàg weak Dirichlet processes with respect to a given filtration. Such a process is the sum of a local martingale and an adapted process A such that [N, A] = 0, for any continuous local martingale N. In particular, given a function u : [0, T ] × R → R, which is of class C^{0,1} (or sometimes less), we provide a chain rule type expansion for X_t = u(t, X_t) which stands in applications for a chain Itô type rule.
