Journal articles
Stability analysis of the POD reduced order method for solving the bidomain model in cardiac electrophysiology
Abstract : In this work we show the numerical stability of the Proper Orthogonal Decomposition (POD) reduced order method used in cardiac electrophysiology applications. The difficulty of proving the stability comes from the fact that we are interested in the bidomain model, which is a system of degenerate parabolic equations coupled to a system of ODEs representing the cell membrane electrical activity. The proof of the stability of this method is based an a priori estimate controlling the gap between the reduced order solution and the Galerkin finite element one. We present some numerical simulations confirming the theoretical results. We also combine the POD method with a time splitting scheme allowing a faster solution of the bidomain problem and show numerical results. Finally, we conduct numerical simulation in 2D illustrating the stability of the POD method in its sensitivity to the ionic model parameters. We also perform 3D simulation using a massively parallel code. We show the computational gain using the POD reduced order model. We also show that this method has a better scalability than the full finite element method.
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/hal-01245685
Contributor : Nejib Zemzemi Connect in order to contact the contributor
Submitted on : Thursday, December 17, 2015 - 3:05:10 PM
Last modification on : Thursday, January 20, 2022 - 5:31:38 PM
Long-term archiving on: : Saturday, April 29, 2017 - 6:33:16 PM
File
Paper-MBS-D-15-00248-Accepted-...
Identifiers
Collections
Citation
Cesare Corrado, Jamila Lassoued, Moncef Mahjoub, Nejib Zemzemi. Stability analysis of the POD reduced order method for solving the bidomain model in cardiac electrophysiology. Mathematical Biosciences, Elsevier, 2015, ⟨10.1016/j.mbs.2015.12.005⟩. ⟨hal-01245685⟩
Share
Metrics
Record views
198
Files downloads
517
