Harmonic-like Identification of Nonlinear Systems around an Equilibrium - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we propose a method to compute the poles of the linear approximation to a non-linear system, locally around a stable equilibrium point. The method uses periodic inputs, just like hermonic identification of linear systems. We show in passing that the class of Wiener-Hammerstein systems is but a small subset of the collection of all nonlinear control systems, locally around a hyperbolic equilibrium.For this we dwell on the exact local topological linearization of linear systems as developed in [6].
Mots clés
HarmonicUdentNL.pdf (680.33 Ko) Télécharger le fichier
hal-01245928 , version 1 (12-01-2016)
Laurent Baratchart, Matthias Caenepeel, Yves Rolain. Harmonic-like Identification of Nonlinear Systems around an Equilibrium. International Instrumentation and Measurement Technology Conference (I2MTC), May 2015, Pisa, Italy. ⟨10.1109/I2MTC.2015.7151338⟩. ⟨hal-01245928⟩
256 Consultations
120 Téléchargements
