Numerical study of the turbulent transonic interaction and transition location effect involving optimisation around a supercritical airfoil - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Mechanics - B/Fluids Année : 2016
The present article analyses the turbulent flow around a supercritical airfoil at high Reynolds number and in the transonic regime, involving shock-wave/boundary-layer interaction (SWBLI) and buffet, by means of numerical simulation and turbulence modelling. Emphasis is put on the transition position influence on the SWBLI and optimisation of this position in order to provide a maximum lift/drag ratio. A non-classical optimisation approach based on Kriging method, coupled with the URANS modelling, has been applied on steady and unsteady flow regimes. Therefore, the present study contributes to the so-called 'laminar-wing design' with the aim of reducing the drag coefficient by providing an optimum laminar region upstream of the SWBLI.
EJMFLU_2015_REV1_150911.pdf (10.74 Mo) Télécharger le fichier
hal-01251813 , version 1 (06-01-2016)
  • HAL Id : hal-01251813 , version 1
Damien Szubert, Ioannis Asproulias, Fernando Grossi, Yannick Hoarau, Marianna Braza, et al.. Numerical study of the turbulent transonic interaction and transition location effect involving optimisation around a supercritical airfoil. European Journal of Mechanics - B/Fluids, 2016, 55 (2). ⟨hal-01251813⟩
Relations
225 Consultations
445 Téléchargements
