Engineering Software Assemblies for Participatory Democracy: The Participatory Budgeting Use Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The worldwide use of the Internet and social networking has transformed the constraints of time and space in human interaction: we can now be heard at a massive scale unprecedented in human history. As a result, ICT may enable citizens to undertake both government through direct assembly and collective action at a scale and an efficacy previously considered impossible. Our research concerns this opportunity to leverage a new sort of political life. We focus specifically on how software systems may enable partic-ipatory democracy, that is, the participation of citizens in democratic assembly, action, and governance. As an initial step, we have developed a service-oriented software platform, called AppCivist-PB, focused on a specific, yet representative use case of participatory democracy, namely, Participa-tory Budgeting (PB for short). PB is an allocation process used in many cities around the world through which they commit a percentage of their annual budget (often 5%) to implement citizen-proposed projects. In PB, residents of a city (or a higher level territorial organization), brainstorm, develop, and select project proposals that local government institutions are required to fund and implement. The key contribution of AppCivist-PB is to enable the cohesive creation of both citizen and software assemblies that together implement a given participatory budgeting campaign.
appcivist_PB-submitted-ICSE-SEIS16.pdf (3.2 Mo) Télécharger le fichier
hal-01261012 , version 1 (25-01-2016)
  • HAL Id : hal-01261012 , version 1
James Holston, Valérie Issarny, Cristhian Parra. Engineering Software Assemblies for Participatory Democracy: The Participatory Budgeting Use Case. ICSE 2016 - 38th International Conference on Software Engineering, May 2016, Austin, TX, United States. ⟨hal-01261012⟩
842 Consultations
597 Téléchargements
