Spherical polar Fourier assembly of protein complexes with arbitrary point group symmetry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Crystallography Année : 2016
A novel fast Fourier transform-based ab inito docking algorithm called SAM is presented, for building perfectly symmetrical models of protein complexes with arbitrary point group symmetry. The basic approach uses a novel and very fast one-dimensional symmetry-constrained spherical polar Fourier search to assemble cyclic Cn systems from a given protein monomer. Structures with higher-order (Dn, T, O and I) point group symmetries may be built using a subsequent symmetry-constrained Fourier domain search to assemble trimeric sub-units. The results reported here show that the SAM algorithm can correctly assemble monomers of up to around 500 residues to produce a near-native complex structure with the given point group symmetry in 17 out of 18 test cases. The SAM program may be downloaded for academic use at http://sam.loria.fr/.
ritchie_grudinin_jac_2016.pdf (882.06 Ko) Télécharger le fichier
hal-01261402 , version 1 (01-02-2016)
David W. Ritchie, Sergei Grudinin. Spherical polar Fourier assembly of protein complexes with arbitrary point group symmetry. Journal of Applied Crystallography, 2016, 49 (1), pp.158-167. ⟨10.1107/S1600576715022931⟩. ⟨hal-01261402⟩
565 Consultations
391 Téléchargements
