On estimates for the $\displaystyle \bar \partial $ equation in Stein manifolds. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Eric Amar
We generalize to intersection of strictly $c$ -convex domains in Stein manifold, $ L^{r}-L^{s}$ and Lipschitz estimates for the solutions of the $ \bar \partial $ equation done by Ma and Vassiliadou for domains in $ {\mathbb{C}}^{n}.$ For this we use a Docquier-Grauert holomorphic retraction plus the raising steps method I introduce earlier. This gives results in the case of domains with low regularity, $ {\mathcal{C}}^{3},$ for their boundary.
AmarSteinLr3.pdf (217.14 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01267008 , version 1 (03-02-2016)
hal-01267008 , version 2 (11-02-2016)
hal-01267008 , version 3 (17-02-2016)
hal-01267008 , version 4 (19-01-2017)
Eric Amar. On estimates for the $\displaystyle \bar \partial $ equation in Stein manifolds.. 2016. ⟨hal-01267008v3⟩
98 Consultations
94 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
