Homogenization of a thermal problem with flux jump - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Networks and Heterogeneous Media Année : 2016
Renata Bunoiu
Claudia Timofte
  • Fonction : Auteur
  • PersonId : 980139
The goal of this paper is to analyze, through homogenization techniques, the effective thermal transfer in a periodic composite material formed by two constituents, separated by an imperfect interface where both the temperature and the flux exhibit jumps. Following the hypotheses on the flux jump, two different homogenized problems are obtained. These problems capture in various ways the influence of the jumps: in the homogenized coefficients, in the right-hand side of the homogenized problem, and in the correctors.
Bunoiu-Timofte-preprint16.pdf (251.08 Ko) Télécharger le fichier
hal-01272936 , version 1 (11-02-2016)
hal-01272936 , version 2 (26-05-2017)
  • HAL Id : hal-01272936 , version 1
Renata Bunoiu, Claudia Timofte. Homogenization of a thermal problem with flux jump. Networks and Heterogeneous Media, 2016, 11 (4), pp.17. ⟨hal-01272936v1⟩
303 Consultations
320 Téléchargements
