Autonomic Parallelism Adaptation on Software Transactional Memory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Parallel programs need to manage the time trade-off between synchronization and computation. A high parallelism may decrease computing time but meanwhile increase synchronization cost among threads. Software Transactional Memory (STM) has emerged as a promising technique, which bypasses locks, to address synchronization issues through transactions. A way to reduce conflicts is by adjusting the parallelism, as a suitable parallelism can maximize program performance. However, there is no universal rule to decide the best parallelism for a program from an offline view. Furthermore, an offline tuning is costly and error-prone. Hence, it becomes necessary to adopt a dynamical tuning-configuration strategy to better manage a STM system. Autonomic control techniques begin to receive attention in computing systems recently. Control technologies offer designers a framework of methods and techniques to build autonomic systems with well-mastered behaviours. The key idea of autonomic control is to implement feedback control loops to design safe, efficient and predictable controllers, which enable monitoring and adjusting controlled systems dynamically while keeping overhead low. We propose to design feedback control loops to automate the choice of parallelism level at runtime and diminish program execution time.
ResearchReport_Zhou.pdf (548.43 Ko) Télécharger le fichier
hal-01279599 , version 1 (26-02-2016)
hal-01279599 , version 2 (22-03-2016)
  • HAL Id : hal-01279599 , version 1
Naweiluo Zhou, Gwenaël Delaval, Bogdan Robu, Éric Rutten, Jean-François Méhaut. Autonomic Parallelism Adaptation on Software Transactional Memory. 2016. ⟨hal-01279599v1⟩
347 Consultations
303 Téléchargements
