Stability Analysis for Impulsive Systems: 2D Vector Lyapunov Function Approach
This paper contributes to the stability analysis for impulsive dynamical systems based on a vector Lyapunov function and its divergence operator. The new method relies on a 2D time domain representation. The result is illustrated for the exponential stability of linear impulsive systems based on LMIs. The obtained results provide some notions of minimum and maximum dwell-time. Some examples illustrate the feasibility of the proposed approach.
Automatique / Robotique
