Highly-oscillatory evolution equations with multiple frequencies: averaging and numerics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
In this paper, we are concerned with the application of the recently introduced multi-revolution composition methods, on the one hand, and two-scale methods, on the other hand, to a class of highly-oscillatory evolution equations with multiple frequencies. The main idea relies on a well-balanced reformulation of the problem as an equivalent mono-frequency equation which allows for the use of the two aforementioned techniques.
multi_arith.pdf (628.74 Ko) Télécharger le fichier
hal-01281950 , version 1 (04-03-2016)
hal-01281950 , version 2 (10-10-2016)
  • HAL Id : hal-01281950 , version 1
Philippe Chartier, Mohammed Lemou, Florian Méhats. Highly-oscillatory evolution equations with multiple frequencies: averaging and numerics. 2016. ⟨hal-01281950v1⟩
544 Consultations
376 Téléchargements
