Convergence of a normalized gradient algorithm for computing ground states - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2018
We consider the approximation of the ground state of the one-dimensional cubic nonlinear Schrödinger equation by a normalized gradient algorithm combined with linearly implicit time integrator, and finite difference space approximation. We show that this method, also called imaginary time evolution method in the physics literature, is con-vergent, and we provide error estimates: the algorithm converges exponentially towards a modified solitons that is a space discretization of the exact soliton, with error estimates depending on the discretization parameters.
Gradient5.pdf (173.35 Ko) Télécharger le fichier
hal-01284679 , version 1 (07-03-2016)
Erwan Faou, Tiphaine Jézéquel. Convergence of a normalized gradient algorithm for computing ground states. IMA Journal of Numerical Analysis, 2018, 38 (1), pp.360-376. ⟨10.1093/imanum/drx009⟩. ⟨hal-01284679⟩
253 Consultations
258 Téléchargements
