New interface
Reports (Research report)
Refinement indicators for estimating hydrogeologic parameters
Abstract : We identify simultaneously the hydraulic transmissivity and the storage coefficient in a ground water flow governed by a linear parabolic equation. Both coefficients are assumed to be functions which are piecewise constant in space and constant in time. Therefore the unknowns are the coefficient values as well as the geometry of the zones where these parameters are constant. The identification problem is formulated as the minimization of a misfit least-square function. Using refinement indicators, we refine the parameterization locally and iteratively. We distinguish the cases where the two parameters have the same parameterization and different parameterizations.
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01285127
Contributor : Jérôme Jaffré Connect in order to contact the contributor
Submitted on : Tuesday, March 8, 2016 - 4:18:15 PM
Last modification on : Wednesday, October 26, 2022 - 8:14:56 AM
Long-term archiving on: : Sunday, November 13, 2016 - 11:05:03 AM
File
RR-8877.pdf
Identifiers
  • HAL Id : hal-01285127, version 1
Collections
Citation
Mohamed Hedi Riahi, Hend Ben Ameur, Jérôme Jaffré, Rachida Bouhlila. Refinement indicators for estimating hydrogeologic parameters. [Research Report] RR-8877, INRIA Paris. 2016, pp.25. ⟨hal-01285127⟩
Share
Metrics
Record views
381
Files downloads
213
