Refinement indicators for estimating hydrogeologic parameters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
Indicateurs de raffinement pour une paramétrisation optimale dans l'estimation de coefficients hydrogéologiques
We identify simultaneously the hydraulic transmissivity and the storage coefficient in a ground water flow governed by a linear parabolic equation. Both coefficients are assumed to be functions which are piecewise constant in space and constant in time. Therefore the unknowns are the coefficient values as well as the geometry of the zones where these parameters are constant. The identification problem is formulated as the minimization of a misfit least-square function. Using refinement indicators, we refine the parameterization locally and iteratively. We distinguish the cases where the two parameters have the same parameterization and different parameterizations.
RR-8877.pdf (4.27 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01285127 , version 1 (08-03-2016)
  • HAL Id : hal-01285127 , version 1
Mohamed Hedi Riahi, Hend Ben Ameur, Jérôme Jaffré, Rachida Bouhlila. Refinement indicators for estimating hydrogeologic parameters. [Research Report] RR-8877, INRIA Paris. 2016, pp.25. ⟨hal-01285127⟩
384 Consultations
233 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
