Efficiency of genomic selection for tomato fruit quality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Molecular Breeding Année : 2016
Fruit quality is polygenic; each component has variable heritability and is difficult to assess. Genomic selection, which allows the prediction of phenotypes based on the whole-genome genotype, could vastly help to improve fruit quality. The goal of this study is to evaluate the accuracy of genomic selection for several metabolomic and quality traits by cross-validation and to estimate the impact of different factors on its accuracy. We analyzed data from 45 phenotypic traits and genotypic data obtained from a previous study of genetic association on a collection of 163 tomato accessions. We tested the influence of (1) the size of training population, (2) the number and density of molecular markers and (3) individual relatedness on the accuracy of prediction. The prediction accuracy of phenotypic values was largely related to the heritability of the traits. The size of training population increased the accuracy of predictions. Using 122 accessions and 5995 single nucleotide polymorphisms (SNPs) was the optimal condition. The density of markers and their numbers also affected the accuracy of the prediction. Using 2313 SNP markers distributed 0.1 cM or more apart from each other reduced the accuracy of prediction, and no gain in prediction accuracy was found when more markers were used in the model. Additionally, the more accessions were related, the more accurate were the predictions. Finally, the structure of the population negatively affected the prediction accuracy. In conclusion, the results obtained by cross-validation illustrated the effect of several parameters on the accuracy of prediction and revealed the potential of genomic selection in tomato breeding programs.
Duangjit et al Mol Breeding 2016_{6ABD7090-CF16-4A60-B4A5-A5776C021873}.pdf (1021.87 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01285248 , version 1 (27-05-2016)
Janejira Duangjit, Mathilde Causse, Christopher Sauvage. Efficiency of genomic selection for tomato fruit quality. Molecular Breeding, 2016, 36 (3), pp.on-line. ⟨10.1007/s11032-016-0453-3⟩. ⟨hal-01285248⟩
166 Consultations
655 Téléchargements
